Found 340 block
dartindanno
Kenosha, WI
Found 340 block, casting numbers 2780930 340 3
Serial number GW340P33980190
Partial Vin 1B310745
I also have the heads from this motor, 1 J head and 1 Z head
Just throwing it out there in case it can find it’s way to the original owner
Yep, the engine serial number.
To match it up to the 1971 car it came from, you need to post the partial VIN as mentioned above.
Knew of a 71 demon 340 3 spd...all yellow, motor too, basket case deal. Guy moved south east.
Did you locate the VIN?
Nevermind. I see you added it. I'm stupid.
I see by the vin it was assembled at Hamtrack so I also posted the info on B-Bodies only site. It would be cool to find the original owner but I know that's high hopes
How much would you want for it. Built same day or week as my plum crazy 71 340 demon
