Found 69 340
CL3406
BC
I will consider letting my 69 340 go if someone is looking for their matching numbers engine. Late 68 build.
Is it missing a digit? Anything after the 7? If the roller dial stamp was worn, the number in front of the seven may
be a light strike. You may have to remove some paint to see if a number is under it.
Yes I am aware there is a missing digit. There is nothing after & pretty sure nothing before the 7 that I can see? If someone responded with all the digits I was willing to take the paint off for further inspection. Until then I would rather not...LOL Thanks for your comments Alaskan TA.
Very good of you to offer up the motor. If I had a car with that vin number and any number 0 thru 9 in the blank spot I would certainly buy it….......so should anyone in that case!!!!!
I'm not sure where your comment is going? Or what you mean? Thanks
i'm saying...if i owned a car with vin# 9B363507
9B363517
9B363527
9B363537
9B363547
9B363557
9B363567
9B363577
9B363587 or
9B363597
and it is an original 340 car.... i would absolutely buy this motor!!
Thanks again for offering it for a possible re-unite to original car, a lot of guys wouldn't do that!!!
9B363517
9B363527
9B363537
9B363547
9B363557
9B363567
9B363577
9B363587 or
9B363597
Got it now! Sorry it was late for me last night when I read this. Ya I am just trying to help someone out as I'm trying to find my own engine. I'm pretty sure there is no number before the 7, I have seen a missing digit before on LA blocks.
Have you posted in "lost and found" looking for your motor? VIN# ?
I just posted one i'm looking for.........
Yes I have a post there. I put it in a couple weeks back.
If the roller dial at the end broke, the 5th roller could have slid over into the last spot?
If you can clean the paint off & look for a ghost stamp from a worn dial number that would be great, the rest of the information could be there just hard to see now.
I may sand it down this weekend & have a look..
