70SwingerGT
Active Member
I found another '66 Barracuda Formula S 273/automatic car, but someone took out the 273 Commando, front sway bar, disc brakes and the 8-3/4. Otherwise, it's all there. Has the 6-leaf rear springs like it is supposed to have and the torsion bars appear to be bigger than my non-Formula S cars.
The VIN on door post matches VIN plate on inner fender (and certicard) and it matches numbers stamped on radiator core support. However, the color up inside the trunk area where you would never see (or paint) does not match. VIN plate says car was blue with blue vinyl interior. Up inside the trunk space is red. Other than that it has all the appearances of a real Formula S, minus the items someone swapped/removed.
I bought it for parts, but it's too nice to pull apart. I'd rather put it back together and have a 3rd Formula S in the driveway lol...maybe put a 5.7 swap in it since it's automatic?
