A friend of mine has a knack for finding broadcast sheets in cars that don't belong to them! A while back he brought home a 69 Charger that had a changed set of seats in it. Wouldn't you know there was a build sheet in the back seat. This is for a 70, U-code, triple black, I believe 4spd, Canadian build Charger. The sheet is OK and I will get the numbers. Hopefully it can be reunited with the car if it still exists.
Then today he drags a 71 Satellite Sebring Plus to my place. It is a parts car. We are looking through it and there are 2 build sheets. One for the car and one for a 71, U-code, GTX. This sheet was stuck in the wrong car almost certainly. The VIN sequence numbers are only 200+/- apart and they are the same color! Likely on the same line that day. Anyway, here is a pic of the 71 sheet. Yes it's rough, but if you own the 71 U-code GTX, it's perfect! The VIN is RS23U1G221283. It is GY9 with V21. It would be cool if someone on the forum knew of or was the owner of either of these cars.
