Keep in mind that the acid in vinegar is eating away at the parts as well as the gunk they are stuck together with. I use Coca Cola which has a lower acid content mixed 50/50 with dot3 brake fluid ( not synthetic). Soak all cylinders with cylinders upright like one bank of a v8 at a time for a week. Then up side down for a week. Try turning the crank both ways daily a couple times. Tap on piston tops repeatedly with a 2x4 and a hammer or just a mallet. Duct taping a orbital sander to the side of the block also helps. Ive had engines where nothing got past the rings to free up the gunk and the piston had to be taken out with shear force.
