front coil over suspension, Pleas help.
matarcher
65dartonly
Modesto, CA
i need to find a company that makes a direct fit coil suspension for a '65 dart gt OR a-body. PLEASE PLEASE help. i have searched the internet for almost three days with no luck. i need the upper A-arm, coil over shock, & mounting bracket set up NOT the intire k-member set up.
Please help! any ideas, links or comments are must apperciated.
You do realize that you just can't convert to a coilover setup with adding to the front unibody structure , the upper shock mount , especially on an a body , was never designed to take the load you will be putting on it .
