1. RichardR
    RichardR Well-Known Member
    131
    2
    Oct 11, 2016
    Harriston, Ontario, Canada
    Local Time:
    10:38 PM
    Hi,
    I've been doing research into changing the front drums on my Scamp and i know you can use a swedge tool or quality hole saw to cut the swedge on the drum. This is where i lose track of what happens, maybe I'm over thinking it. After the drum is cut and the hub removed, can I just go and buy new drums and install as is with the same studs since the hub centers the drum? Is the swedge on the studs being cut or is it just the drum?
    Thank you
  2. RedFish
    RedFish Well-Known Member
    23,291
    2164
    Sep 5, 2007
    Local Time:
    9:38 PM
    The studs will stay fixed into the hub. New drum simply slips over studs, no reswedge possible or req'd.
    • Agree Agree x 1
    • RichardR
      131
      2
      Oct 11, 2016
      Local Time:
      10:38 PM
      Awesome.
      Thank you.
      5/8 hole saw correct?
    • RedFish
      23,291
      2164
      Sep 5, 2007
      Local Time:
      9:38 PM
    • RichardR
      131
      2
      Oct 11, 2016
      Local Time:
      10:38 PM
      Thank you
    • RedFish
      23,291
      2164
      Sep 5, 2007
      Local Time:
      9:38 PM
      Will the less expensive 5/8 hole saw work? In a hand held drill motor? I don't know. Drill press and cutting oil would be recommended for either cutting tool.
      • Like Like x 1
      • 69FBCuda
        69FBCuda Life in the Fast Lane
        1,446
        630
        Aug 28, 2014
        Florida
        Local Time:
        10:38 PM
        I used a cheapo hand drill and a lot of attention on my part, keep the drilll square to the drum. With 1/2" stud you will need the 11/16" hole saw, 5/8" is to tight and will cut the threads. Cutting oil!
        While installing the new drums you may have to "clean up" the studs to get the drum all the way on.
        Ace hardware for the holesaw $7-8
      • RichardR
        131
        2
        Oct 11, 2016
        Local Time:
        10:38 PM
        Thank you! :)
        • Like Like x 1
