Ironracer
Gearhead
Okay so I just put new lower control arm bushings and pins in the 74 Duster. Also used the old (not available) moog strut bushings. Used 1 each side moog offset upper control arm bushing. Have 2 more. Are they needed? Seems the the lower ball joint is way in front of the upper. The car had a leaf added. Shes lifted. Had to use longer rear shocks. The question is this, can I drive the car from my carport, back it out, turn it, drive it up on the grass, drive across the lawn and park it on a flat slab to set my ride height and then torque everything down? I left the LCA's finger tight, and just snugged up the struts. I know you got to roll these things around to get things settled. Driveway is slanted like a leftist. So if I jack it up, shove a bunch of blocks/ plywood, shims,ect, underneath the passenger side, front and back to get her, level and all that Madness, then I just have to let it back down, roll it back and forth, and then Jack it up, and play with all the blocks of wood again. It it safe to drive her? Thank You!
