Front end noise
74 Slant Six
Elk Grove Ca.
Looking for some help on the front end of my 1974 Duster. On the passenger side eveytime I go over a bump it makes a "clunking sound" I have replaced the following items. Motor mounts, shocks, new upper control arms, all ball joints, tie rod ends and adjuster sleeves, outer wheel bearings. I have checked the strut rods and pulled the wheels and tried the the stock steel ones all with the same results. It's starting to get very frustrating. Any suggestions would be greatly appreciated.
Thanks,
Bill
I had a clunking on the right side of my 69 Dart when I removed everything for the front end rebuild i found my lower controll arm bushing was shot big time have a look there.Jack it up wheels off the ground loosen the ride hight adjuster all the way loose, then grab the lower arm have a look at the pivot pin that goes into the k frame and the bushing look for any looseness.Hope that it is ok there my 2 cents.
