Front end torque specs
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
Getting the Scamp ready for its maden voyage. Does anyone have the front end torque specs suspension and steering. Ive tried to load the service manual but cant get it to load on my computer.
2-14
TIGHTENING REFERENCE TIGHTENING REFERENCE
0
Foot Inch Pounds
................... 125(Min.) -Upper (Except Dart) .......... 100
(Disc Brakes) ............... 115 Upper ............................ 55
Ball Joint-Upper Nut-Lower ....................... 100
(Dart) ................. 55
Strut Nuts Front (Dart) ...................... 40
Control Arm Pivot Shaft Nut ................... 130 Rebound Bumpers .................
........... 50 Frame Bracket Bolt Nut (Dart) .....
Crossrnernber Bolts ................. 150 Engine Mounting Bolts .............. 85 Idler Arm Stud Nuts
200
(Coronet-Charger) Rear ............................. 100
at Center Link .................... 40
Link Insulator Retainer Bolt Nut
at Mounting Bracket .............. 65 Shock Absorber Nu&-Front
Tie Rod Ends Sleeve Clamp Bolt Nut ............ Stud Nuts ........................ 40
115
Lower ............................ 50
Upper ............................ 25 Steering Gear Mounting Bolts ........ 80 Steering Knuckle Bolt Nuts
Wheel Nuts Except Dart ....................... 65 Dart .............................. 55
Lower(Coronet) ................... 120
Coot Inch Pounds
(Dart) ...................... 100
Sway Eliminator Shaft
200
.... Link to Frame Bracket Nut ........
100 100
Haha James I did google search and you posted this up 2 years ago here lol.
upper ball joint nut................55
lower ball joint nut................100
lower control arm pivot nut.....145
control arm upper cam bolt.....65
rebound stop nuts.................25
crossmember bolts................150
idler arm mounting nuts...........45
shock absorber lower mounting....50
shock absorber upper mounting....25
steering knuckle bolts (lower)....100
steering knuckle bolts (upper).....55
drag strut nut (front)...............40
drag strut nut (rear)................110
anti sway bar nuts...................30
tie-rod end ball joint nuts..........40
tie-rod end clamp pinch bolts......15
steering box mounting bolts......100
pitman arm nut.......................175
One thing you really need to ask is "why won't the service manual load?"
I assume you downloaded the '72 manual, which is a common .pdf file, and should display "on about anything." What do you have for a puter?
There's LOTS 'o good info in those, and worthwhile to "fix."
Maybe the file is corrupt? delete and download again?
Im guessing its because my laptop is old and slow.. Ive been able to load them before but for some reason today they wont load.
OK, you are evidently using a a machine with which you can get on the net, right?
I'm guessing you are trying to "load" the file directly from the internet. Instead, try saving the file on your desktop, and then opening it from there. At that point the file will be opening from your hard drive. Also try to figure out if you have a bunch of un-needed "junk" open, so close all software and open windows when you try and view the file.
And, what file did you download?
This is the 72 manual that AbodyJoe posted:
Even and old Windoz95 machine should be able to open this file. You do of course need a .pdf viewer, the most popular of which is "Adobe reader." But there are others
[ame]http://www.abodyjoe.com/pictures/Misc.%20car%20info/1972%20Plymouth%20Chassis%20Serv%20Man.pdf[/ame]
Are the bolts/studs I am pointing at in the photo called "steering knuckle bolts"? (I would have called them "backing plate bolts"). Thank you. (trying to find torque specs-they are a bear to loosen after 50 years) This is a 1965 Valiant I am working on.
