Front fender emblem Barracuda -67
swedefish
Sweden
I`m about to put the front fender emblems on my -67 Barracuda fastback.
Some owner from the happy seventies did weld the pin holes.
Can any of you guys give me the correct location or a link where I can find the location for the emblems, it would be most appreciated.
It`s the "Barracuda" and fish emblem at the front of the fender it concerns.
Many thanks in advance
Len
This is crude, but I`ll try to help you here Swedefish, this is a sketch of the left front fender. Use the center of the bolt hole for the fender bracket and the raised body line of the frt. fender to create a 90 degree angle. Measurements will be from the body line (up and down) and from the center of the bolt hole (side to side). Hope this helps Len.
Great, thanks Longgone
That`s better then what I could wish for :thumbup:
I`ll show you the final result when it`s done.
