xLURKxDOGx
"An angel fat, at satan's feast"
I just put my new engine and was having massive amounts of issues with that and now it seams all that bad luck is being passed on the the transmission. Its a 64 SB 904 that was floor shift/pushbutton that was supposed to have been rebuilt within the last 10000 miles so i thought nothing of it. I looked over the valve body and it looked clean as well as the gaskets.
So, it appears to be leaking from the center on the bellhousing, it doesnt do it when its idling in neutral so it only a guess. I suppose its possible that its a bad converter but i dont know if that a obvious sign??? Its only when ive come back from a short drive and i look and its sprayed all over the underside, on the pan, exhaust pipes, everywhere. I looks like it wasnt over filled/overheating. I have transmission lines running into my champion radiator. Any insight would be great.
Thanks again!!!
Jake
Thanks again!!!
Jake
