Front skinny tire question
early A Bob
youngsville, NC
Ok you guys gave me some good advice on my last question. Thank you for that. So I have another. On my 64 Barracuda Drag Car im rescuing. Is it ok to run a VW Beetle Tire. It’s the right height & width & a lot cheaper that drag skinny’s. Anything bigger will rub as seen in the pic. $50 ea for the VW tire vs $140 ea. for drag skinny’s. I ran VW tires on my last car but it was a lot slower.
I destroyed both of my fender's and cut the tires on my 64, they fit good but I was backing up and turned the wheel hit a dip and the tires caught the fender and that was the end.
VW tires have a load rating of about 800 lbs and a speed rating of ~55 mph.....check both. I went from a Nanking VW to a Michelin XZX due to load rating. For a driver you can get away with the lower speed rating but watch the load rating.
I have run VW fronts since ~2001 (165-R15's). Hundreds of passes at 125mph (a couple of hits at 130+ screwing around). They have treated me well.
If you need more room look for 155 80r15 instead of 165 80r15.
Pic is bfgoodrich radial TA 155 80r15 on
1965 dart gt
I ran the VW tires on my '65 Valiant bracket racer. I believe the speed rating on tires is more related to cruising at high speeds taking into consideration heat build-up. My trap speed was 108 mph, which I only held for one or two seconds. That does not stress the tire much.
I had a 65 Valiant with 340 that ran 12.0s at 108 with VW fronts also. Mine was blue
I dont understand why folks would go cheep on frontrunners.
To be honest I was surprised at the cost of skinny tires but dam if I'm gonna run some half *** tire after all the cash I already spent and my *** sitting behind said tire.
All it takes is one failure.
I guess I don't understand why you'd chintz out on front tires? You spend thousands of dollars to go fast but don't want to spend a couple hundred bucks on safe front tires...
My car is a street car mostly, I wouldn`t even run new drag tires on the front, they are too flimsy .
I think you na sayers have it backwards. The drag race front skinny’s are the cheap ones as far as you wouldn’t want to put THEM on a street car. They are lite weight & engineered for low rolling resistance. They have a higher speed rating that’s true. That & the fact they are low sellers is why they cost more. As far as a 55 MPH speed rating on a VW tire I’ll have to look into that. With nationwide speed limits of 70 mph that’s surprising. When I bought the pair I ran on my 69 3200 pound B body the tire guy ( life long friend) told me I’d be fine. Had them on the car for 7 years before selling it & noticed no wear at all. Hundreds of passes. I just wanted to see if anyone has ever had a problem with a set on a Drag car. I see others have run them too. I will talk with my tire guy again. He knows which brands have problems. Thanks again to all.
I agree. I think the speed rating is more for heavy hi powered street cars that may see sustained speeds over 100 mph as compared to a much lighter drag car going in a straight line with 100 -110 for 2-5 seconds. Above 110 I would definitely opt for a true drag tire.
My front drag tires are 8 ply load range E so they're not light duty. Max load 1450 lbs @ 60 psi and they weight 19 lbs a piece
