[SOLD] Front spring hangers
Can you install these and flip these for even lower drop? or does the extra hole negate doing that?
From the looks of it, I think the second mounting location is there so you don't have to flip them. I haven't put these side by side with a stock one, but the lower hole is supposed to the the stock location. If that is the case then the second location is actually higher than if you flipped a stock hangar.
Thanks for the reply. I think I will hold off. I have SS springs and was looking for drop back to stock. I will try to just flip mine first.
