I have been searching for a fuel filter that has a 5/16 inlet and a 3/8 outlet. The steel line from my fuel pump is 5/16 and the inlet for my edelbrock carb is 3/8. I currently have a cheap spectre glass filter that you can plumb with different sized inlets. It's ok, but I would rather run a higher quality filter. I was thinking about changing the carb inlet to 5/16 so I could just run any 5/16 in/out filter, but I can't seem to find a 5/16 inlet with the correct 5/8 in.-20 Male Thread. Any suggestions?
