Fuel Gauge Question
Mopar Interiors
  1. Dan_the_Mopar_Man
    Dan_the_Mopar_Man Member
    5
    0
    Apr 17, 2018
    Central New York
    Local Time:
    1:01 AM
    Gotta question regarding my 1974 Duster fuel gauge. It's not reading accurately, when I fill the tank it goes over to full, but after driving 30 miles it's already on half, I know I'm not burning that much gas, plus when I go to refill it at half, it barely takes anything to fill it again, so it's moving over to half way too soon. Any ideas?
    Dan
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    812
    399
    Apr 19, 2010
    San Jose, California
    Local Time:
    10:01 PM
    And there is no change in the oil pressure gauge ?
  3. Yote
    Yote Well-Known Member
    1,167
    474
    Aug 30, 2015
    far eastern Colorado
    Local Time:
    11:01 PM
    My '72 Demon gauge operates in a similar fashion. Maybe not to 1/2 in 30 miles, but the first 1/2 seems to drop pretty quickly. The bottom 1/2 takes a lot longer. My sending unit is an origional from a Duster '73 or newer, not sure of exact year. If you are thinking of replacing the sending unit the new replacements are much worse.
    Yote
    • Agree Agree x 1
    • Hellrats
      Hellrats Still wrenching after all these years FABO Gold Member
      834
      540
      Jan 24, 2012
      N.E. Ohio
      Local Time:
      1:01 AM
      If it's an aftermarket fuel tank sending unit none of them read correctly. Do a search on here there is lots of information on ways to fix it.
      • Agree Agree x 1
      • cannucky
        cannucky The Guy With No Birthday
        5,720
        651
        Sep 25, 2008
        Portage Du Fort QC
        Local Time:
        10:01 PM
        If it's a stock ralleye gauge that internal voltage regulator can do some weird things to your gauges , had 1 where the temp and oil pressure gauges would climb as the fuel was consumed , both read correctly with a full tank but each in turn would climb to max as the fuel went down , both maxed out after burning about 2 thirds of the tank LOL .
      • Mr.FT
        Mr.FT FABO Gold Member FABO Gold Member
        855
        30
        Feb 14, 2011
        New Jersey
        Local Time:
        1:01 AM
        • Thanks! Thanks! x 1
        • 67Dart273
          67Dart273 Well-Known Member
          38,654
          6263
          Oct 14, 2010
          Idaho
          Local Time:
          10:01 PM
          Do a site search. "We" have posted hundreds of posts about this.
          The gauge unit may be out of cal
          The instrument voltage limiter by any other name may be "off"
          The sender especially if it's a "repop" is a large problem
          The factory gauge tester (read your service manual) was a switchbox with 3 resistors, to simulate the senders at low/ empty, mid scale/ 1/2 and high/ full. Here is one version. Someone kindly added the resistances to the photo:
          ...........so you can also do that "backwards." These test boxes were meant to be put from the sender wire to ground, but you can ALSO "let's say" you know you have 1/2 a tank of actual fuel. "Let's say" you know this because you drained it, filled it and measured it, and then ended up with 1/2 that "measured."
          This means the sender when unplugged, and measured with an ohmeter, should read somewhere around 20-25 ohms
          If it does, and the gauge doesn't read that, then the gauge/ cluster connections/ IVR is some-ting-wong.
          Also notice from the tester resistances that THESE GAUGES ARE NOT linear!!! In other words, twice as much sender resistance doesn't change it from MT to 1/2, and twice that much does not result in "full"
        • 67Dart273
          38,654
          6263
          Oct 14, 2010
          Idaho
          Local Time:
          10:01 PM
        • jed
          jed Active Member
          36
          16
          Apr 12, 2009
          Local Time:
          1:01 AM
          My stock pickup in my 72 Duster was doing same thing, pulled it out float looked perfect but it was half filled with gasoline. Put new float in, works perfectly now. -Jed.
        • toolmanmike
          toolmanmike FABO Staff Staff Member FABO Gold Member
          35,280
          17238
          Jan 18, 2006
          Iowa
          Local Time:
          12:01 AM
          • Like Like x 1
          • famous bob
            famous bob mopar misfit
            11,242
            2784
            Aug 14, 2011
            okla
            Local Time:
            12:01 AM
            ---------------$105-----------
          • Mr.FT
            855
            30
            Feb 14, 2011
            New Jersey
            Local Time:
            1:01 AM
            I've been using the Meter Match mentioned above for @ 2 years now. I've had zero issues with it in my 72 Demon 340.
            • toolmanmike
              35,280
              17238
              Jan 18, 2006
              Iowa
              Local Time:
              12:01 AM
              Stock gauge?
            • Mr.FT
              855
              30
              Feb 14, 2011
              New Jersey
              Local Time:
              1:01 AM
              Yes stock gauge and replacement sender. The sender was a direct replacement from Jegs if I remember correctly. It would read full when I filled the tank but when on empty it would only take @ 8 gal to full. That is why I installed the meter match and all good now.
            • MrJLR
              MrJLR Built, not bought FABO Gold Member
              4,149
              2798
              May 14, 2015
              Chino, California
              Local Time:
              10:01 PM
              Meter Match unit ordered....I'll chime in with my results after installing.
              Jeff
            • Mr.FT
              855
              30
              Feb 14, 2011
              New Jersey
              Local Time:
              1:01 AM
              I hope you have as good of luck as I did.
              • MrJLR
                4,149
                2798
                May 14, 2015
                Chino, California
                Local Time:
                10:01 PM
                My MeterMatch unit arrived today.
                Looks simple enough....I'll try to install it this weekend and I'll report back!
                Jeff
              • moparmandan
                moparmandan FABO Gold Member FABO Gold Member
                1,072
                637
                Jun 28, 2017
                Central FL
                Local Time:
                1:01 AM
                If you have to have to have the factory look, like everyone says, meter match. If you don't care put a matched aftermarket gauge under the dash. Under the dash was easier. I was mounting gauges there anyway. Reads perfectly.
                • Like Like x 1
