Fuel ground strap
Moparornocar51
Austria
Hi guys i knew where and how to put the ground strap on oem fuel lines but how i get ground if i have an aftermarket line like this one
http://www.ebay.com/itm/Stainless-S...aterials_Plumbing_MJ&var=&hash=item43ad8fef4c
i have a 1/2 aluminium line from the front to the rear wheel and then i go with the stainless steel line to the sending unit, my question is how can i get ground with the grounding strap??
Thx Peter
I'm not even sure you need a ground strap with those metal hoses.
Any piece of wire from the sender body to the car body will work.
X2...use a band clamp and clamp a ground wire to the sending unit and screw it on the rear frame rail.
