clair.davis
catching up...
EFI Guys/Girls, Let's Talk Tuning.
I'm sure there are at least a few folks here that have DIY'd their own EFI or installed a kit that required some tuning. Let's get some nitty-gritty discussion going on what you've found to work for you on your particular setup. What I'm looking for is guidance or clues on where spark or fuel tables need some special attention to run well. Things you've found in your project that may have seemed strange but made a difference you could feel are important.
Let's also give some basics on our particular systems... I'll start...
Mine's GM-based, a batch-fired MPI from a 90-92 5.7L Z-28. Tuning is via software and an emulator that replaces the hard-coded chip until I get the tune right. Burn the chip, install, forget about it.
Engine is a 72 340, about 8:1 CR, cleaned-up 360 smog heads, Crane HMV272 cam, TTI headers and pipes, nothing wild at all. Made ~300hp at the crank (260hp @ wheels) with a TQ on a Stealth intake a few years back. EFI intake is a 4bbl MP M1 single plane, with a MP 1000cfm billet TB on top. 24lb/hr injectors, Ford F150 fuel pump, Aeromotive regulator, Lean Burn distributor... what else is there?
I need to sort out my spark table for sure, and do some more work on my base fuel table before I can start to fine tune my acceleration and power enrichment routines. I'd love to see how y'all have done things, and pick up any hints I can apply towards my project.
Thanks!
Clair
Thanks!
Clair
