tbr1806
I pulled the fuel pump because I suspected a bad diaphram. Well, I was right, it's shot.
There is a difference in the new pump vs the old one. On the arm of the old one, the one that rides on the cam, there is a spring that sits about halfway and then connect s to the body of the pump. The new one does not have this, I am assuming it is just a change do to aftermarket parts, correct? Thanks for the advice.
