As stated I found a purple mist on the secondary bowls of my 950 XP. Is fuel sloshing up the bowl vent and getting blown back through my air filter? Just noticed this. I do run purple fuel. Anybody seen this before?
It's certainly possible but wouldn't you see it on the gasket also? There looks to be a lot on the well plug though.Is fuel sloshing up the bowl vent and getting blown back through my air filter?
You're going to need a go pro under the hoodThere was a fine mist covering the entire bowl around the bottom too. Not wet. Ya I see the fuel in that plug on top. This seems to be a 1 time thing. First time I've seen it in 5 years with this carb. I think this must have happened this year on a cold late October Sunday. Confusing.
I suppose it's possible but I hadnt oiled that filter in a bit.Is it simply air filter oil?
I will pull the bowl and metering block off and re gasket before the spring.
