J&Bs71Demon
Active Member
By using the search feature on FABO I have received some very good advice from the folks who take their time to share their knowledge. For the past two weeks I have chased a suspected fuel, timing, or electrical problem.:banghead: During the search I have been forced to address other problems with a slightly modified 42 year old car .
Less than an hour ago I decided to pull the fuel sender in order to put my mind and wallet to rest. The picture is of the sender I removed. The PO probably thought it was a good idea at the time.:violent1: It is definitely a fine example of shade tree mechanic ingenuity and one that I might have used 40 years ago if I had given some thought to it.
Thanks again for a great site. If you are able to please support FABO.
