Fuel Tank Sending Unit: Calibrating a new one to the original
69DartDave
Seattle
Retrofitting EFI into a slant6-powered '69 Dart has been mostly fun, but also a little frustrating. Frustrating due to some unintended consequences, but I hope that others can use this information to learn from and maybe apply to their own projects.
The biggest change (other than the 2" hole you gotta drill in the firewall to route the new wiring harness through) is the fuel system, and my son and I knew that before making the decision:
  • You need a bigger feed line diameter, a 3/8".
  • And you need to add a new fuel return line.
The fuel no longer will just dead-head at a carburetor inlet; now it is pressure-regulated to stay at 22psi (for the Holley Avenger kit, at least). Excess fuel not needed to maintain 22psi is sent back to the fuel tank.
The car came with a 5/16" diameter fuel feed line. Which is great, since you can re-use that as the return line.
The rub is: the fuel tank sending unit. If you want to re-use it, you technically could for a slant-six powered Mopar. Just put an 5/16-to-3/8 adaptor just outside of the tank to neck upsize the original line before the fuel filter. The fuel flow rates for a slant six are low enough to be fed by a 5/16 line, so long as the entire run isn't 5/16. Then, add a new return line that terminates at, say, the fuel tank fill tube (there are aftermarket fittings to help do just that).
But that's not what we did. We bought the only off-the-shelf sending unit I could find that has both a 3/8 feed and 5/16 return line built-in to the bulkhead. Which I thought was great. Maybe I should have looked around more? It was, after all, listed in RockAuto's web site as fitting a 1969 Dodge Dart 3.7L car. But the Ohm range is advertised as being different than stock, which I didn't know enough at the time to pay attention to. Who knows what the stock range is? (yes, I should have researched it more)
Bottom line: The stock fuel gauge is now going to be WAY off.
How much? Well, I did some instrument testing of the stock sending unit and the new sending unit, as well as estimated the height/volume relationship of the fuel tank itself (not linear due to not being a perfectly rectangular box). When the gauge first reads empty, there's still going to be about 7 gallons present. :???:
Here are my findings. Skip the first two plots, unless you're a nerd like me.
The conclusion is that I need to replace the stock fuel gauge with an aftermarket one that is properly calibrated to the new sending unit. That is do-able, but something I'd rather not have to mess with. Live and learn (and share the story).
The bottom-most plot is pretty cool; the original calibration has been reverse-engineered here to prove that Dodge did a good job with the stock unit providing a nice, linear full-to-empty gauge reading.
Anybody know who makes a fuel gauge that's calibrated to 10 ohms full and 80 ohms empty?
If anyone made one, and any of us knew, it would be "all over" this site one where and how to get, LOL
THE OTHER THING you must keep in mind is the "rest of the system"
The wiring connections, the IVR output and the condition of the gauge itself!!! None of that may necessarily close to "in cal"
I hope the sending unit I bought for my Dart will work with my fuel gauge. I didn't even think about checking the ohm range. Granted mine was listed for my Dart. I only needed the 3/8 out and don't need a return line. Looking forward to seeing what you come up with.
The OEM fuel gauges are thermal. They have 13 inches of nichrome wire inside that is either 1.0 ohms per inch at 70 degrees or 1.5 ohms per inch at 70 degrees. So OEM fuel gauges ( depending on model and how many gauges the limiter is running ) are 13 ohms internal or 20 ohms internal at 70 degrees. Materials and production tolerances are factors also so any of those numbers can vary slightly. That's why the gauges have adjust features. Anyway....
Here's the part that most don't comprehend... the nichrome wire resistance changes with its temperature. That's why 1/2 the range is 23 ohms and not what the novice with a calculator would believe, 35 ohms. My point is that a calculator cannot tell you what 1/4 range, or 3/4 range is either unless the resistance @ temperature scale of the nichrome is factored into equations. Someone should have educated Wong the chinaman before he started producing fuel senders. Good luck to all.
. Someone should have educated Wong the chinaman before he started producing fuel senders. .
Would that be "Sum Ting Wong?"
You been hangin around me too long, LOL. You mean to say they've been "chineseoated"
69DartDave,
I made a circuit that measures the tank sensor and independently drives the gauge with a PWM (variable duty cycle signal). It was only a few $ in parts. While simple linear curve fit was involved, other methods such as lookup table with interpolation would provide more exact response. If you are into DIY it is an option. Your ability to characterize what you have and plot is impressive. That information can be used and incorporated in the lookup table.
http://www.forabodiesonly.com/mopar/showthread.php?t=264543&highlight=calibration
How do our gauges adjust? I don't recall coming across that. thanks
Provisions are in the back of the gauge so production workers can tune away the variances. They are not for end user adjustments.
I probably should have never mentioned that. Its too easy to feck up a gauge.
....I probably should have never mentioned that. Its too easy to feck up a gauge.
Now you've done it! Send all gauge adjustment complaints to Redfish....
just kidding.
Actually, it's good you mention it to keep folk away from there. Now we know it's best to leave those production settings alone.
thanks for the info.
But let's just say for instance, that someone did F around with the 2 adjusters on the back. How would you un-F it up?
Thanks
Thanks
Good question. I don't have a good answer though. Adjustability varies with gauge type. Some of them are too close to the end of available travel from day 1.
In any of them.. what looks like slots for rotating a screw driver is actually where a blade tool pushes the internal parts left/right up/down. Twisting a screw driver in those can bend the internal part.
