Fuel tank venting
Dusted73
Vermont
I have a 73 duster with fold down rear seat, getting ready to layout the fuel system and was wondering the best way to vent it. The car was gutted when I got it so all the factory stuff is gone. Should I get a sending unit with 3 ports, supply return and vent or put a bulk head fitting in the top of my filler neck and loop a line back down through my trunk and attach it near my rear shock mount for a vent?
That's how the factory did it in 67. It might be you have a venterd cap?
If you have the skill I would duplicate the non evap AKA 70/ earlier setup. Braze or otherwise install a fitting up high in the filler tube, bring it up high in an upside down "U" near the top of the fender and back down the tube through the trunk floor gasket
The original vent was the 1/4" tube going clear up into the engine bay and connecting into the "carbon can" evap control system
As mentioned above, I would go with the original vent tube into the engine bay and connect it to the "carbon can" system. The carb would vent to it too. I would go that route, you just need the second fuel line.
There are 3 tubes in your pic, 1 from the filler neck or tank, 1 to the carb or intake cover. Where does the 3rd go?
Sorry, it has taken this long, I was away. Here's a page from the tech book.
That may or may not be correct IT IS SO FUZZY I cannot read it. Go to MyMopar.com. Download the FREE 73 service manual, WHICH GOT THERE because of GUYS RIGHT HERE
The service manuals over the years have sections on fuel, the tank, and emissions which lay out how these were put together and how they worked.
THE 1/4" line coming up from IS THE VENT. There IS NO VENTED cap, that is, not operationally. The cap has pressure/ vacuum pressure relief valves, they are NOT vents. Be careful of caps. They changed nearly every year after the evap stuff got rolling
Post no2
Sorry about the pic I sent. Here's the pdf format.
  • Canister.pdf
