Rapid Robert
circle track mild 360. 6K at the end of the straights. clearances slightly loose. which should I go with? thank you for your time. RR
I was thinking of getting 2 sets to accomplish this IF it is very desireableFull groove Clevite if you can find them, if not half groove will suffice. 65'
Clevite ms 1266p fully grooved
Clevite Engine Parts Main Bearings DODGE 5.9L/360 Mopar small block LA - Upper and lower Groove Location - Free Shipping on Orders Over $99 at Summit Racing
Speed Pro make a 3/4 groove bearing ....probably for 3/4 race engines..lol
Speed Pro 120M - Speed-Pro Competition Series Main Bearings
I've found very little selection for full groove bearings.
King makes a very nice looking set....they offer them in coated versions, too. The only problem is.....you can't actually buy them. I had a set on order for 6 months...the carrot they dangled continued to move out 3 weeks every 3 weeks. I finally cancelled them. That was after I took the time to call King and get through to their tech line, and the guy there said they were 'in the works' but also sounded like their level of urgency in producing these was a 1, with 100 being the best.
I have some Clevites that are full groove, but they are not the .001" looser race type, and I think there was one other thing about them that made them not as desirable.
Full groove.circle track mild 360. 6K at the end of the straights. clearances slightly loose. which should I go with? thank you for your time. RR
I have a tendency to believe you though there is that little chance the seal just leaked and when you put the new ones in the new seal.. didn't. but in consideration of that I wonder if just swapping out that we are bearing and leaving the rest would be the fix.when I raced I found the fully grooved bearing would cause a oil leak at the rear main getting the clutch wet , by accident we got the wrong set with no time to change after installing the 1/2 grooved ones this stopped the oil leak just a reminder you should drill a small hole in the thrust surface of the bearing so if your hit and the clutch linkage binds it wont wipe out your crank thrust surface (ask me how I know)
I used to have a fixture I could slap the bearing in, shove it in the lathe and grove the other half. Of course, when the Iowa prick fired me I lost all that stuff and I doubt the Mexicans who ended up with all the equipment had a clues as to what 85% of the staff was.
You can make one. I need to make another one. It seems like full groove bearings are on the way out.
Just a comment...I was talking to Dan Dvorak Friday on the phone. He's the well known Max Wedge racer...also does a lot of various Mopar engines for others. He commented the small block is the hardest engine to avoid rear main seal leaks, and that too-high oil pressure is the #1 cause. He also said what I kinda already do...install the seal without any sealer or silicone, and do not stagger the seals. He said he looks at each seal and rejects the ones that don't fit in the cap/block slightly taller than the parting line.
The rear main seal leak in SBM's is more prone to happen when the high pressure oil pump is used versus the high volume pump. Or someone changing out the spring to increase pressure.
