schwinger
1972 Dodge Dart Swinger
DId some research on this carb that they say is one of the best out their so i ended up buying one, rebuilt it and slaped it on my 318 dart and Dam it woke up the engine, great throttle response and pulled great but the primary float got stuck on a hard acceleration wich flooded it out so i unstuck it and went on my way, Fiddling that out later and has barely alittle cuttout problem at part throttle wich im still working on that. Has no ported vacuum port wich sucks for the distributor but then again my total advance before with the carter carb was all the way up to 55 so i figure i not hook it up and run it which its still running fine. Working out the kinks but Wonder if anybody has had experience with this carb on a mopar before?
