73 duster 340 was a slant6 car with column [ auto] i coverted to floor [auto] steering column is from a floor shift car 73 also. the key switch works some times but most of the time i jump the soliniod the amp meter sometimes goes to H when i turn on the fans it goes just past the middle so what causes the fuseable link to get so hot but not blow
These old girls are getting old, and have a way of developing troubles. a couple of big issues, other than general rust and corrosion that affects any vehicle of this age, is the "full current" ammeter that Mopar used for years, and the bulkhead connector, which was never designed for the current they must pass on a few of the connections.
If you can, you might post some pictures of the bulkhead connector/ starter relay/ fuse link area to illustrate the condition. Another cause of "things getting hot" is just plain loose or corroded connections.
Your starting problem, (jumping the relay / solenoid) could be a few things. If you do NOT have the horrid seat belt interlock system, the general starting path is:
From the big stud on the starter relay, through the fuse link, through the bulkhead connector, to the ammeter, to the ignition switch, back OUT the bulkhead on the yellow "crank" wire, to one of the push-on connectors at the start relay, out the OTHER push-on connector, down to the transmission, to the center pin on the backup lamp/ neutral safety switch, and ground.
If all that works, so far, when you twist the key, the STARTER RELAY will pull in.
NOW the path is--from the big stud on the start relay, which is fed from the battery, through the (now closed) contacts on the start relay, down to the starter small stud which is the solenoid connection.
IF THAT PART WORKS, and also IF the biggest cable going to the starter "big" stud is OK, the starter will "pull in" assuming the solenoid is OK, and crank the engine
So to troubleshoot these problems, you need wiring diagrams, a test lamp, and a multimeter, which you can buy nowadays at any auto store for about 25 bucks.
Download a service manual here:
http://www.forabodiesonly.com/mopar/showthread.php?t=132309&highlight=manual,+download
Or there are some rather "redrawn" diagrams here:
http://www.mymopar.com/index.php?pid=31
some good info here:
http://www.mymopar.com/index.php?pid=18
and finally some wiring diagrams:
http://www.mymopar.com/downloads/1973/73ValiantA.jpg
http://www.mymopar.com/downloads/1973/73ValiantB.jpg
(True diagram is in the shop manual)
