Gaps and holes
fastmopar
fastmopar06
Carson City
I have a .020 bored 318 with 360 heads.
The aluminum Edelbrock Intake leaves a gap in thecenter of the head. It matches the contour of the intake runner. Not a hole in the intake runner. This above and surrounding the runner.
Is this normal? Will it leak coolant or oil? Do I need some sort of plate to block it? Do I need a different manifold?
I have a set of aluminum valve covers. Each one has a hole and a cap.
Do I need a breather in one of the covers? Both? what about a PCV valve? Do I need to drill a hole for the PCV?
Thanks,
fastmopar8)8)
The gap is not problem. Factory intakes do that too. You need to drill out one cap hole, get the right sized grommet, and run a PCV on one side. The other side, you just drill out the rear hole and using the right grommet again, run a breather.
