[FOR SALE] Garage cleaning-Indy intake, JE pistons more
jhnycuda
Lancaster, Ca.
Doing a little garage cleaning-
New Melling M72 SBM oil pump-$40
340 rods-12 total-SOLD
360 balancer$40
440 steel crank balancer-$50
SB rocker set-$40 cleaned
BB rocker set-SOLD
8.75 yokes-2 small u-joint yokes, 1 is fine & the other is coarse thread-$30 each, 1 large u-joint-new-$50
New MP master cylinder adapter-4 hole to 2-hole $40
Indy RB MW 4500 intake-$500
JE used pistons/pins-499"-4.375 bore / 4.15 stroke / 1.094 pin $250
742 case-4.56 gears less than 200 miles, 35 spline Moser spool-$700
Parts are in Lancaster, Ca, I accept PayPal, contact me here via PM
I have 400ci the is bored to 4.375 I'm using stock rods I can't remember what the piston pin size is 1.03 or 1.99? would these pistons work?
Thank for the info I think I'll pass . I am already 1K on the block and have a forged steel crank from my 383 block along with some good stock rods all for the low deck. I have price piston for about $700 just trrying to save some cash.
360 balancer$40
BB rocker set-SOLD
8.75 yokes-2 small u-joint yokes, 1 is fine & the other is coarse thread-$30 each, 1 large u-joint-new-SOLD
JE used pistons/pins-499"-4.375 bore / 4.15 stroke / 1.094 pin $250 SOLD
Thanks, the right hand healed well from last December, the left isn't, was done Nov.15.
I am in SoCal, shipping may be kind of high to Md, I will weigh it while I have it out.
