Need to clean up, save these parts from scrap!!
List of parts in picture.
Assortment of pulleys for LA sm blk, 1 crank pulley is for AC! 15.00 ea.
4 shifter rods, 2 are for A body, 2 are for ?, must take all, 40.00
4 barrel sq bore to 2 barrel adapter, unkown brand, 10.00
2 solid motor mounts that were on my 318 barracuda. 20.00
2 clutch forks, 25.00 ea
trans Linkage set up from my 318/904 that was in my 67 barracuda, 35.00 for all
Above parts shipped at buyers expense.
Parts I have not shown in picture,
A body power steering pump and gear box, Ill throw in new correct hoses. 50.00,
A set of 273 exhaust manif, heat riser works, needs cleaned up. 25.00
I have a 318 that ran when pulled with a 904 that shifted sitting in garage. I pulled heads on 318 for a buyer that backed out. 904 has an upper case crack repair, (omg), but worked fine. both good for cores or assembly and run. parts still together, 150.00
Non pictured parts are pick up only, in Coatesville Pa
All parts shipped at buyers expense.
First come first serve. If you PM and dont post you will still be first in line, If you post and dont PM your time mark will determine where you are in the list.
