Look to find an NOS unit OR a nonfunctional OE unit that you can have repaired.Any advise on where to get a good sending unit?
That helps a lot,I would have never figured there was so much to troubleshooting a nonfunctional gauge,thanksFirst do as others have said and measure the resistance that the sender is providing to ground.
This chart is from my aftermarket sender vs my NOS sender.
yours should have similar readings at a particular gallons in the tank.
you can see on the chart that the NOS mopar sender is not linear but the aftermarket on is.
Non linear matches OE gauge Linear gives bad readings on OE gauge
View attachment 1715213080View attachment 1715213081
I'll start looking,thanksLook to find and NOS unit. OR a nonfunctional OE unit that you can have repaired.
tell me about it. As you can see from the chart I added and removed one gallon at a time to create the resistance charts.That helps a lot,I would have never figured there was so much to troubleshooting a nonfunctional gauge,thanks
I saw a photo of a confirmed NOS 67 and the tube layout and the location of the reostat and the length of the arm the float is on are very different from my later production NOS and the aftermarket ones. I agree that all you mentioned will effect the graph now let me toss in one more for you...How do the bends on the float arm and the position of the sweeper box compare between the OE and the aftermarket?
The shape of the tank. If it were a pure rectangle one gallon added would raise the fuel level (just for example but not in reality) 1 inch the next gallon another 1 inch etc. but a-body tanks are tapered on the bottom so the fuel level will rise at a non linear rate till the level is above the tapered area, then it will raise lineally till it hits the carved out area for the spare tire.
I have seen the winding on aftermarket senders and they do seem to have the same number of winding per inch throughout the entire range and on at least one OE sender they were not.
ALSO (but I don't know this for sure) the gauge might have its own non linearity. I was building a resister box to prove that out but haven't finished it yet.
Yes one gallon at a time!Did you generate this yourself, or where did you get this?
Yes same tank but if the OE sender is "calibrated" to the tank or the gauge or both I suspect that is why you see the difference in profiles on the graph.I assumed you were testing both senders in the same tank, so the tank shape would be removed from the equation.
This is interesting. Better than trying to find an original sender.
Having replaced all fuel related pieces in my 68 fastback, and the dam gauge still aint right, it makes me want to go to a 20gal fuel cell !
