Another "bell on the cat" topic.
People are interested in the product, but noone wants to be the one to possibly get hurt.
We need more dirt trackers into Mopars, they aren't scared of NOTHING!
As far as wiping out main bearings, I'd say that's not a plausible defense to not trying it out, here's why:
'66 to '71 Mopar Big Block Industrial engines were gear-to-gear timed and never had issues.
These engines had TREMENDOUS crank loads, some were even actually driving accessories with the crank snout!
How many 240/300 Ford 6es ran multiple hundred thousand miles with no issues?
GM used gear-to-gear in the "Iron Duke" 151, also a long lived and durable little 4 cylinder.
Then there's the Cummins Turbodiesel and numerous other diesels out there, are they going to have main bearing failures?
These are all very durable and long-lived engines and, except for the Ford's poor rocker arm/stud design, quite stable.
These, except for the Industrial Mopar, are all engines that have been made with gear on gear timing for many years, most from original concept.
NONE of the engines above were ever prone to, or experienced, main bearing failures due to the timing components causing undue loading.
Ever broken, or seen broken, a timing chain on a smallblock Mopar? No?
Why on earth would you expect to break a gear drive?
Truth be known an idler gear, which the set-up above has, same principle as Milodon, actually REDUCES loading.
Mark.
