gear ratio problem
fat-lip-resto
mn
got a dana with 3.56 and a four speed 26" tall tires and i am at 4200 rpms at 70 mph what the %#^* is wrong
Well, the small tire is a problem with that.
Clutch slipping? Old clutch, preesure on the plate from a miss adjusted fork?
the clutch is new he doesnt think its slipping and he is sure it is shifting i am at a loss the car is not here and i am trying to diagnoss over the phone and do not know what else to tell him
Are you sure its a 3:56? Did you get the ratio from a tag or did you actually count the revolutions to be sure?
i worked it up on a ratio calculator and i think he put 4.56 instead of 3.56
My calculator says 4.56 gears with 26" tires will spin 4123 rpm at 70 mph so you might be right that he installed the wrong gears. 3.54 gears should only turn 3200 rpm at 70.
Only other thing that hasn't been mentioned is maybe the tach is 1000 rpm off?
