3.23's work well with a 3.09 low gear four speed, not so much with a 2.66 low gear. Not with a small block, anyway. Just my opinion based on my own experience.
it likely has the 2.66 1st. but trust nothing and verify everything, these cars are 50+ years oldWhat would my 69 833 have
Or do I need to open it up
But the automatics have a torque converter to multiply torque; 4-speed does not.it likely has the 2.66 1st. but trust nothing and verify everything, these cars are 50+ years old
also, i wouldn't worry the slightest about a 2.66 1st. it's deeper than a 904 (2.45) or 727 (2.54)
it'll be fine with 3.23's as long as you don't have like 28" tall rear tires.
different strokes for different folks i guess.But the automatics have a torque converter to multiply torque; 4-speed does not.
My 65 Barracuda was fast off the line with a 3.09 low gear and 3.23 gears; it was a dog off the line with 2.66 low gear. Then I figured out I could run my original gearset in a 69 trans. End of problem.
clutch style sure grips for the 8-3/4 diff have NO springs as shown in your pictures ,, look at the cheap 8-3/4 clutch type units on e-bay to compare yours to ,, post a pic of the center pin in your sure grip case ,,want to see if the pin has oblonged the hole in your case which means its scrap, there are NO replacement parts available for the cone type so if your case ,, side gears or spider gears are shot you have to locate another unit to salvage parts from.is there a way to tell without taking apart
So cone type is the better one
Should I re-gear this one if it's good
Don't really want too tight of a posi
heres pics of the pin not easy to seeclutch style sure grips for the 8-3/4 diff have NO springs as shown in your pictures ,, look at the cheap 8-3/4 clutch type units on e-bay to compare yours to ,, post a pic of the center pin in your sure grip case ,,want to see if the pin has oblonged the hole in your case which means its scrap, there are NO replacement parts available for the cone type so if your case ,, side gears or spider gears are shot you have to locate another unit to salvage parts from.
@junkyardheroit likely has the 2.66 1st. but trust nothing and verify everything, these cars are 50+ years old
in the 2nd pic looks like the center pin bore is oversized which means your pin has spun in the bore or the pin has a super large chamfer on the end which i doubt , so you probably have a junk unit ,, do your self a favor and buy a new clutch style unit . parts are available for these and they work very well .i build a lot of differentials the cheap ones on e-bay are not the one you want . they have a couple issues i did not like so i sent the one i bought back.heres pics of the pin not easy to see
looks tight ,its been apart gear oil has a glitter back lash is a little too tight for me ,didn't put a dail on it
so is this a better diff or should i look for a clutch type ...
www.forabodiesonly.com
@RustyRatRod used to re-machine and rebuild the cone style. I don't think he still does but it can be done. .the cone type work better in real world driving situations on greasy surfaces. is a torque biasing integral or seperated cone limited slip differential
basically the cones are sacrificial part.
if the side gear and cone are integrated as one part...you have a problem when the cone is worn..new cone and case set is not available.
if the cone and side gear are seperate parts, and the cone sits outside of the side gear on the axle spline in the case, you can machine the ends of the cone down a few thou so the friction surface of the cone hits the case again and you put shims in between the gear and cone. Enough shim so that the cross or single shaft "just Just" seats in the respective case halves. or take out 2 thou of shim and have it tight... wear out quicker but more aggressive bias
either way you maintain spider to side gear mesh and all is well
this kind of rebuild is usually dismissed as a shoddy thing to do, possibly driven by people who have only encountered the integral cone version, that can't be rebuilt
but this is how all of the 5.5 inch to 8.8 inch borg warner axles in Australia and south africa were manufactured. If they needed shim on assembly they got shim from day 1 if they didn't, they didn't. The australian versions are supported for parts for the 7.6 inch 7.8 inch M76 M78.
and cones and side gears come in 25 28 and 32 spline axle which i think are SAE sizes
both types should have an oil vent/ window that shows the end of the cone and its distance from case end near the bearing mounting sections
if you can see a gap between cone end and case end face. near where the axles go...its a goodun
clutch plate version more aggressive, less good in mud, easier to rebuild, parts available, heavier, more parts to go wrong
me.... i just got torsen/ true track style centre and put all of my old diff centres on the shelf.... no more messing about.
only problem you have with them is a 2.77 2.92 3.23 3.5 :1 gear set has such a fat pinion head the tha "fat barrel" centre to the truetrac might rub on it, with the correct pinion depth setting in place. so you need to machine a few though off the rear facing face of the pinion, and of course then you lose the pinion depth info stamped into it...record that before machining to save wasting time later on messing about with spacers and shims
3.5 3.9 4.11 :1 small pinion head no problems
dave
