noisyboy
I just picked up a pair of Gilmer style gear kit for my 360 engine. I have installed a crank gear with spacer and water pump gear. I need to move my alternator up about 1 1/2 inches with spacers to line up the alternator pulley which is the main guide which keeps the belt on all pulleys lined up. The problem is I have no power steering due to Gilmer gear does not make a pulley for the power steering pump. Any suggestions? I am going to take a standard water pump flange and bore out the center and press it on to my power steering pump and align it properly and then install the same Gilmer gear for a water pump and use a longer Gilmer belt. They come in all sorts of sizes. If anyone has ran into this problem please advise. thanks..
