ramenth
Gratis persona
As was posted not too long ago the worst engine ever thread I stated the 3100 and 3400 GM V6.
These engines never cease to amaze me in what I can find wrong with them. Besides the penchant to blow intake gaskets.
Last Christmas I did a set of blown head gaskets in a Montana minivan. No problem. Overheat an iron block/aluminum headed factory engine, that's what you get.
Not too long ago had to replace a short block assembly for a young lady with a Silhouette which broke a cam in a 3400. Majorly f-ed up the upper end. Valves and push rods bent like you wouldn't believe.
Had one dragged in last week in which the previous owner was told the engine was blown. 3400 powered Alero. New owner expects to have to put in an engine, but I'm not convinced after seeing 8 quarts of something or other in the oil pan registering on the dipstick. Smells suspiciously like gasoline. Engine won't even turn over because of the extra drag on the crank.
Drain the oil, refill, engine runs on five cylinders, slight tapping in the upper end. P0301 code showing. Number one plug looks like it hasn't done much in ages, good compression, but what's the tick? Pull the valve cover, number one intake rocker is on with just a couple of threads. Pull it, chase the thread to clean em up, tighten. Seems to be an issue with these engines, especially after someone has done intake gaskets. Roll engine over by hand. Number one exhaust valve is barely moving. Pull the rocker and find out the push rod has pushed through the rocker. They have now become one part. Replace both. Roll engine over by hand to watch for motion. Pull the fuel pump relay, all the plugs, (hey, I was turning it by hand, easier that way) and roll engine over to make sure it's oiling. Good oil. Button up. Running like a champ.
Get a call yesterday to tow another one in. 3100 powered Pontiac with a ticking. Owner is sure the engine is blown. After a little noise chasing come to find out the torque converter bolts are loose. Granted, this one isn't the engine's fault. Repeat after me: "Loc-Tite is my friend."
But it makes me wonder what the heck else I'll be messing with on this engines...
The plus side on the last two, though, is being able to tell the customer that for just a little bit of time and a few parts, instead of major repair bills, like a new engine, they now have a running car.
