Goals and advice needed
If looking to do 12's I'd go 360/5.9l but can be done with a 318.
Here's an article what it took to do high 12's (12.76/103mph) with a 318 and dyno results.
https://www.hotrod.com/articles/mopp-0311-318-engine-buildup-and-dyno-test
Test 1-Stock 318 with two-barrel carburetor, 1 5/8-inch Hedman headers, and 3-inch exhaust system with mufflers.Test 2-Rebuilt 318 with 9.8:1 compression ratio, pocket-ported 318 heads, 340 cast-iron intake manifold, 625-cfm AVS carburetor, and Giles Performance single-pattern camshaft.Test 3-Same as test 2, but with Giles Performance dual-pattern camshaft.Test 4-Same as test 3, with ported 360 heads.Test 5-Same as test 4, but with 360 cast-iron intake manifold and 750-cfm Thermo- Quad carb.
RPMTest 1Test 2Test 3Test 4Test 5
CBTCHpCBTCHpCBTCHpCBTCHpCBTCHp
2500305145326155347165360171364173
2750303158336176357187369193371194
3000297170338193364208373213377215
3250286177338209366226375232379234
3500277184233222365243273249378252
3750262187337241363259371265377269
4000246187343261369281378288385293
4250230186343278270299381309388314
4500214184340292365313380326388333
4750197179331299356322372336380344
5000180171376301341324362345371353
5250163163298298324324346346357357
5500146153279293306321330345339355
5750290317312341321352
6000271310295337302345
CBT= Corrected brake torqueCHp= Corrected horsepowerHorsepower and torque corrected to 29.92 inches/Hg barometer, 60 degrees, with dry air.
To me looks like 5750 and 6000 rpm's are in the wrong boxes and should be moved over 5 spots.
Looking at the chart on the hot rod website.. seems odd to have such a spike from 5500 to 5750? Also what’s a safe rpm to spin a stock 318 to? I figured 5000-5300 would be it ?
When they put there magazines online some of the numbers on the charts got moved I put them where I'm pretty sure they belonged.
55 is "safe" but i wouldn't press much past that without better rod bolts and knowing the bottom end: rods, pistons, rings, bearings-- types and clearances, and oil pump/pick up.
well put together they're good to 6+ all day
If you look after I fixed the dyno graph that 318 generally peaking at 5250 rpm no need to rev it too much pass peak.
I wondered about that.. even if ya could spin it 6000 on stock parts.. your power waved bye bye long before that lol
It depends on the build and what you are trying to do.
If you are really going to run quarter mile, then we generally shift a bit past peak Hp and try to get through the finish lights near peak Hp. If the engine is more torque focused, and the car has good chassis and some sort of sticky tire, then you can get some of the et off the line. When running street tires, where we get poor traction then the game is more about making use of the hp.
As an example let's look at the wheel power produced by Zebra Dart with the 318. This is a road course car, that was also autocrossed and driven to events. Baseline is the engine as built by the previous owner with machine work done by Dick Ott, and had a cam selected to produce power well past peak. @CPDave bought the car and continued its development. Lamehorse Racing
Anyway, the points here are
1. Changing from 273 exhaust manifold to headers unlocked the potential of that of that original combination with power increase from as low as the dyno would show to well past peak.
2. Depending on gearing and tires, a shift point past peak might well be warrented. This happens to be a 2.66:1 4 speed car with a 3.55 diff. It was very responsive off the line when I drove it.
3. A good valve job and some head work (if legal for your class) can go a long way. IIRC the new heads also bumped the CR slightly.
This is a bit of a loaded post since it’s not as simple as a single question and answer. While the stock 318 in my 68 Dart runs well I know investing the same amount of money in a mag 5.9 will yield much better results. My goals aren’t really achieving a specific horsepower number. I’d like enough power to maybe get my car in the 12.8-12.9 in the heat. I say that goal because in Louisiana, it’s warm/hot most of the year.
I found a couple of 5.9 magnum options locally. One at a U-pull it for $500 (including the price of them pulling it for me). It’s in a 2000 Durango 4wd. Miles are unknown. It looked pretty clean and the only concern was the oil cap was missing because of fear of water getting in it. Second option is one from a private seller close to where I live that’s also in a Durango. Supposedly it has 120k miles on it and an older couple owned it. The seller said that it was running and driving recently but he’s parting it out and the transmission has been sold out of it currently. He wants $350 for it and he’s gonna pull it.
With all that being said.. what kind of power will I need to be in that range of ET? I have a 4 speed and a 3.55 gear. Could I even get my 318 to do those sort of numbers without totally just setting money on fire?.. I know the stock 5.9 can get to mid 300hp relatively easy.. main thing would be reliable, fun to drive, and if it can bust off a high 12 in the 1320… I’d say mission accomplished..
The appeal of the 120k mile motor (if he’s not full of crap) that it’s still fresh enough to not need a full overhaul.. I know these engines can possibly last well beyond that miles wise.. machine shops locally are few and far between where I live..
Stuff like this can snowball fast and in the end, it would of been better to do XYZ instead..
I wish I could foot the bill for a blueprint 408 to drop in but..if I can achieve my goals much more affordably, I will.
Any advice is appreciated… I’ve never dug into the innards of an engine but I’m confident I’m capable should I need to. I know the heads are prone to crack and the cost of stock replacement heads aren’t quite as cheap as they used to be (like everything these day).. almost better off with promaxx heads or something if that’s the case
I'm always going to pick the 5.9 Magnum junkyard engine. Send the cam to Oregon cams, get a hughes spring set, carb intake, weld up a factory electronic distributor to get the curve.
Let it run what it runs and have fun. Generally every upgrade made to make it go faster is a takeaway from streetability/durability.
