ultimatejay
Hi everyone, new member here. Just bought a good condition 1970 Duster with 225 slant 6 that has supposedly 85k original miles for my son and i to work on. Drove it home 60 miles and then about 5 miles from home it started running rough/backfire/stalled. Got it started and limped it home. Once home the engine would not start and when it did it ran rough. Long story short I found the ignition condensor failed due to overvoltage. I put new condensor and checked battery voltage and found 16-17 volts and battery was fizzing out of vent! The previous owner just put in a new alternator, cap, rotor, points but did not replace the voltage regulator. So i went to local auto parts and bought what was in stock which was a POS china crap. Installed it and it did help dropping it down to 15-15.4 volts which is still too high. Did search here and checked some things recommended by other members. What i have checked
1. voltage regulator ground is good
2. Tried another known good battery- same issue
3. disconnected field terminal and /VR terminal and charging stopped
4. REmoved bulkhead connectors at firewall and looked and cleaned them. They all look pretty good- no corrosion
5. Checked and cleaned all grounds. Although i did notice there is no ground cable from block to firewall. There is a small ground off main battery ground that goes to front radiator support. I assume this is the ground for the chassis or is there supposed to be another from engine to firewall?
6. I tested field wire to positive battery cable with key on engine off and had 1.2 volts. I assume this is my issue as i have a voltage drop from wiring somewhere? If that is the case, where to go from here to find the issue? Also, I had similar issue with my Chevy c10 and i went through 2 china alternators and 2 VRs until i someone told me to get a solid state VR and that solved my issue so I'm worried my new china VR might not be up to par. Please help me I have been messing with this for 2 days now. This is my first Mopar so I'm green on knowing where everyting is. Thanks for any help
