Going Racing!
Dusted408
Member
Midwest
  • X Block sleeved @.060 416 project build @IMM Engines
  • Stroked with Molnar Rotating assembly
  • Wiseco gas ported dome pistons 14.5:1
  • Indy 360-1 rectangular port. Ported @ Indy and finished by Brian
  • Flow @322cfm
  • Harland Sharp 1.6 rockers
  • Comp cam custom Roller .720 lift
  • Indy 360-3R intake
  • Kevko oil pan
  • TTI 1-7/8” 2 Race headers 3-1/2” collectors
  • 4.10 gear
  • Reverse manual 727
  • 5000 stall from Alan @ A-1
  • 29” Hoosiers
  • Going in a 3100lb 72’ Duster
Bolted to the engine Dyno ready for some pulls on Monday.
I use A-1 Converters also and they have been very good.......not sure although who specs out a converter before the engine gets dyno'd unless an engine wasn't going to get dyno'd and then I think best they can do is ball park it from experience but since you stated that yours is getting dyno'd Monday why did Alan spec it at 5000 prior to a dyno sheet? Seems a 5000 stall might be a little short anyhow but a dyno sheet would prove or disprove that out.
Where is A1converters located ?
My fault on the converter. I gave Alan the specs before finalizing on the motor particulars. Although it should flash to 5500.
Just curious how tight you twist your motor, shift points and through the lights, quarter mile?
Should go 137-138 ish pretty easy at that weigh. 9.70’s with good hook and everything working well together.
Should be 645-650 horse.
Might like a bit more gear with that 29 tire. Has potential to go even faster.
Local racer i race with has a similar deal, but a glide, runs 9.60’s in good air…Duster, Indy’s, less compression.
That engine should make at least 700 hp. If it doesn’t there is something wrong.
9.60’s in the 1/4 off the trailer
