Good Cheap Headers?
oleyeller
Member
Working on a tight budget(Alot of that around lately) What if any are decent not hanging to low headers are out there, for a ps small block A body? Thanks!
Click on the word "forums" above and scroll down to the exhaust section.
There are posts about Spitfire headers made by Harold. They look pretty
good and are supposed to fit and work good .......and the price is right.
Sorry I didn't realize you had a Demon. I don't know wether Spitfires will fit that application.
toolman
Hedman or Flowtech are in the sub-$200 range. I have Hedmans on my '75 Duster 318 with p/s, p/b, a/c, and although tight, they have enough ground clearance. I should add that I am running 15 inch tires/wheels. Do yourself a favor and get the best fastening bolt system you can find with high end gaskets. You can run Mopar high performance oil filters(short ones).
I would go with Hedmans, I had a cheap set of ceramic coated Dynomax headers once and they were all rust within 1 year!
Except toolmanmike, because I don't know about those headers, All the answers given are not correct, the answer is none. All headers listed hang below the front end parts like he didn't want.
The only headers I know of that do not hang low like the normal typical 3 tube hangin low headers are the TTI's and Doug's headers. Both expensive. Doug's are cheaper but still cost a bit. Look @ summit racing.
http://store.summitracing.com/partd...840085+4294908078+4294908074+115&autoview=sku
or
Ahh, yea, posted that. ( ??????????? )
