Ok I just wanted to know is this normal. This 360 has been sitting for years and I'm finally getting into it. Green paint on the block under the intake? Peeling in some places, Normal???? I didn't expect this
Not normal. Somebody thought the oil would drain better. If it doesn't make a lot of horsepower don't worry about it. I don't like peeling paint inside a engine.Ok I just wanted to know is this normal. This 360 has been sitting for years and I'm finally getting into it. Green paint on the block under the intake? Peeling in some places, Normal???? I didn't expect this
I would have the shop vac running while chipping the paint off. Tip it over and pull the pan. That paint has to settle somewhere. May be in the pick up screen.Hmm, I might attempt a cleanup
YES!!! YES!!! I'm number 1There always has to be 1. Thanks
It looks normal now!
Now, paint it metallic.
I'm still confused why someone would do this.
