Big_John
In my defense, I was left unsupervised.
I flattened and bent a male spade connector and soldered it to the sender. Ran a wire to the frame with a female connector on it.
If you have the sender out, I've thought of this very thing.I was going to suggest a machine screw, drill and tap sender,then solder inside. Not going to break off. Then you have a ground stud.
Dang spell check... It should have read: "wouldn't be a worse ground..."Then we are in agreement. Don't know where the wires crossed. It was me I'm sure. lol
Genius, I like it.I flattened and bent a male spade connector and soldered it to the sender. Ran a wire to the frame with a female connector on it.
