Grrr!!!
GermzD74
Cool Member
San Diego, CA
What is is frikkin right way to start a car back up after you run out of gas!?!?!
I am struggling getting the pump to suck the gas up again, I'm sure I am doing something wrong...what is the right way, all I do is pour gas in the carb, crank and crank and more crank till it starts, it doesnt stay on much so I run out and pour gas into the carb to let it run for more time, and nothing yet...my paitence is dead!!!
You could disconnect the tank line at the fuel pump and use an air compressor to lightly pressure the tank at the filler necktill fuel is to the pump then with one prime it should crank unless the sock in the tank is plugged . If it is blow out the line from thre other way pump to tank.
pourin gas in should work, try holding choke close and have someone turn it over if that don't get thegas to carb somthings wrong, mabey pick up some trash
