yes thats my dash,, i did all the work,,not to hard,,its been a while but ill tell you what i remember ask and ill try to remember,,or ill go look under the dash,,,
the only thing orignal is the dash face,,the circuit board is completely gone,,
the smaler gauges were not on the market when i started this dash,, i called auto meter and asked what it would cost for a custom size,,,they told me the size i needed was soon on the way,,,,the small gauges are 2 1/16 round,the center 2 are 5 inches round,,,
to instal the smaller gauges,,all i had to do was use a drum sanding paper,,round piece of sand paper on a mandrel,,i didnt have to remove to much plastic,,,i sanded and checked,,sanded and checked,,those smal gauges just push in,,,nice snug fit,,they come with a metal bracket and a rubber band type piece,,i put the rubber band gromet on the back of the gauge after it was installed just to keep it from moving,,remember they fit snug,,so no fear of them faling out,,,
the 2 center gauges are a different story,, if you take your front dash bezel off and remove the plastic factory gauge cover,,,on the inside of the hole it is painted black,,looking from the back of the dah bezel,,i cut out that black part with an exacto knife and snaded it till the big gague went thru,,,on these 2 gauges i used the metal mounting bracket supplied with the gauge,,to hold them in to the bezel,,,all new wiring to the gauges,,i do have another dash bezel ready to go,,when i get reay to have it refinished,,,so i dont have to remove the one im using,, i could take pics of it and post or e mail to you if you would like to see,,
thanks for noticing and for your intrest,, feel free to e mail me if u have questions
fstfish66@aol.com thanks don
