I thought that I would do a kinda "how to" on Ray @halifaxhops Slant 6 HEI ignition. It's a nice kit and easily adaptable to the stock slant 6 electronic ignition distributor. I'm not quite done with it, but follow along on what I have done so far and I'll update more later.
Here is the distributor upside down. You can see the new drilled drain hole and the tapped hole for the HEI plate. The drain hole gets tapped to 10-32. Then the new drain hole is drilled.
Don't mind the RTV. It was there for another project. lol
This shot shows the HEI plate fit. The fit is nice, as you can see. The innermost two holes on the plate, closest to the distributor shaft are the two holes to mount the module. The two outer holes are for the two tits on the module to locate it. I said tits. (*) (*)
Here it is with the module located and installed. Yes, I put the included heat sink goo on the module.
Another angle. When you get the tits lined up, the module will mount flat down on the plate like this.
Lastly, from the "top". This kit is nice and an easy way to convert your slant 6 to HEI. I'll post more pictures when I get it finished. Thanks for following along.
