Handling - Sway Bar & Shocks
73moparx3
Franklin, tn
Just finished installing Addco front sway bar from Just Suspension($99 +$30 fgth) on my stock 73 318 Scamp(63k miles). Took 2 1/2 hours to install. Had to drill hole in each lower arm. Unbelievable difference in ride and handling. May handle better than my Cordoba now. Also have set of Monroe Sencematic coil over shocks in rear.
i'm going to do the same install next week! I hope my results are as good as yours!!
Cool !
I'm doing similar, a little at a time. My ebay purchased OEM front sway bar just arrived (67 model). I still need info on ears for end links at lower arms. Those bushing kits ordered also.
I hope to add the Hellwig rear sway bar someday too, but only after installing the bolt on style frame ties and changing rear springs from 4 leaf to 6 leaf (got those onhand*). Doubt I'd ever upgrade the shocks beyond basic gas charged replacements.
*note to self, order spring eye bushings
The best upgrade I ever did to ant car was the front sway bar. Night and day difference in the way the car handled.
