downsr
Have 70 duster that the brake pedal is really hard to push.Going to try and bleed brakes to make sure fluid is getting to each wheel cylinder.Any one have this problem.Everything in the brake system is new
Ever since i done the brakes it has had a high hard pedal .But for some reason it is a lot worse.I was thinking if the regulator to the back wheels was not working it may cause this that is why i was going to see if fluid came out of all wheel cylinders and how much pressure
I do not know what the bore size is.It has factory disc brakes and the master cylinder is new from right stuff
