harmonic balencer bolt
franko60
oregon
how can I torque this bolt down; with out removing oil pan; and what is proper torque for this bolt??? thanks franko60
For starters...........what engine, in the car, out of the car?
Engine in the car, remove dust shield off tranny, or remove starter, stick a screw driver, pry bar, what ever works to wedge ring gear so it won't turn as you tighten bolt.
Engine out of car on stand, use 2 flex plate/ flywheel bolts in crank hub so that you can stick a heavy duty long screw driver / pry bar in between so it will lock up against engine stand as you tighten bolt.
Small block bolt torque, 135-140 ftlb.
HELLO from OREGON: thank you for your response: will try that methoed of locking the flywheel; iam working on my 72 demon with 340 moter/ 4-speed
thanks again franko60
four speed!!! simply put it in gear and chock the wheels.
