Just thought I would share my install pictures. Some may have all ready seen these in my build thread pro touring 10k. Let me first say that Dennys HDK suspension is top quality. I build these car for a living and I install a lot of aftermarket suspensions. The HDK is very nice. you wont be disappointed. So here is my set up . 2" wilwood pro drop spindles. wilwood 13" rotors with 6 piston radial mount calipers. Wheels on the front are 18x8 6" B/S with a 235/40/18 tire 25.4 over all diameter. wheel and tire set right in the center of the wheel well. front crade sets at 6 inchs off the ground and front fender at its lowers point is right at 5" . The pixctures are set at ride weight. hope this helps some one considering the HDK set up.
