What’s the best plan of attack to fix this. Thanks. Kim
Aluminum. There is room on the pr side. Kim
I was thinking of getting it tiged but was concerned that they may blow a bigger hole in it then have even more fun. Will epoxy take the oil running over it?
That would be great. Thanksabsolutely. Scratch, rough it up some and clean is as much as possible with an oil free cleaner. I like to seal it and do so every time I have the head off. I don’t know if you ever say my epoxy test but if you want to let me know and I will try to find the link.
Copper Or brass ?You can TIG or MIG it with a consumable backer and then grind off the excess.
Copper Or brass ?
****, my buddy repaired his hippie *** VW bugs fender with splash zone, he was a tug boat dude & he will die for splashzoneBelzona is the best epoxy out there but it’s very expensive. Darrin Morgan really liked sealed Splashzone so I started using it and really like it. I threw my Morosso AB epoxy away.
Oh I see what you mean, I was thinking of welding a build up of materials, I hate to think of all the bs contaminants coming out welding in a intake port....just from my own attempts on the outside of a used intake manifoldAluminum. You can use copper or brass but that wouldn’t be consumable. Ive done it both ways and they both work.
Yeah, the 1st time I used it I was amazed @ the ease of shaping & it is durable...great shtuffOne thing I really like about it is you can sprinkle a little water on it and smooth it out with your finger like PlayDoo. I throw on a harbor freight thin rubber glove and dip my finger in water and smooth and shape away.
110 or 112. May mix with pump premium. It will be 11-1 compression. Timing locked at whatever it likes. KimJB weld a piece of thin shim stock to the PR side.
Add some JB smeared on top of that.
After that cures, smear a layer in the port.
This is only if you’re going to use fuels without alcohol.
