header dr. side???
Nite Moves
Belleville,ontario,canada
Im at the point of putting in the drivers side header in my 67 Dart with the 318. Pass. side done and it was a bit of a pain. Question is????????????????????I have power brakes, starter is off,as well center link.do i need the booster off as well whats the best way to put it in? Top side or from the bottom
Depending on the header,, most go in from the bottom,, you may need to lift that side of the engine a bit,, and it shouldn't come anywhere near your p/b..
hope it helps..
Its a headman header and motor mounts are loose as well. Got the dart up on blocks so from the bottom.............That saves some work. Thanks
Yeah sorry it's just a giant pain in the ***. Like he said about all you can do is lift the engine up a few inches to help. Or buy Doug's. I thought the price was crazy but after breaking down and buying them, life is much better, install is so much easier!
